Snow Plow to Winch
Old 03-14-14, 10:15 AM
Snow Plow to Winch
My Club Car golf cart has a snow plow with a Cycle Country Work Power Electric Lift.
When I remove the snow plow, I want to add a winch.
I want it to slide into the 2" receiver and plug into the existing power / remote cord.
It seems to me it would be doable if I could get a cable to connect with my present cable.
Old 03-14-14, 10:34 AM
Do you have a question?
Make sure your existing wiring will support the electrical load a winch can demand. The one on my Gator is protected by a 150 amp breaker and the winch can pull 170+ at max load.
Old 03-14-14, 10:40 AM
Welcome to the forums.
Obtaining those connectors is not a problem as they are widely available.
You do need to make sure that that wire can supply enough power/current to run your winch. The wire appears to be very small in your pictures which would indicate that there is not enough power available on that wire for the winch.
Those disconnects come in wire gauge size from #20 thru around #8.
Google " 2 pin 12v disconnects " and you'll get many links. eBay, amazon, etc.
