Yamaha Zuma won't start
Old 07-28-14, 09:56 PM
hi every one I have a Yamaha zuma I tried to clean the carburetor and when tried to put it back it wont start I checked all the lines and problem seems to be fuel wont flow on its own I have suck the vaccum line and every time I do that fuel starts to flow and then stoped I am trying to direct fuel line to carburetor lets see any suggestions >?
Old 07-29-14, 02:54 AM
pugsl's Avatar
Take the fill cap off and see if the fuel will flow than. If does than tank is not vented. Don't know how it is vented.
Old 07-30-14, 08:17 AM
Did you remove your fuel filter in the process?
If it's an in-line filter, is it possible that you put it backwards?
Old 07-31-14, 02:22 PM
I believe that model may have a vacuum fuel valve. Check and see if there are two nipples on the petcock. One would be for fuel and the second for a vacuum line. The vacuum pulls open a diaphragm in the petcock to allow fuel to flow.
