What type of adhesive to use?
Old 09-23-14, 12:02 PM
I was attempting to remove the backfire screen from the airbox on my Honda CRF230F when I realized it is glued in place. Since I have now compromised the seal, I would like to remove the screen and re-glue it. I'll also be cleaning it at the same time because I got rim grease all over the perimeter of the screen. What type of adhesive would work best to adhere the metal screen to the plastic airbox? I'm assuming it would need to remain flexible and be waterproof, but at the same time not permanent so I can remove the screen in the future to clean it again if necessary. Would regular silicon caulking work?
Old 09-23-14, 12:10 PM
Gunguy45's Avatar
Super Moderator
I'd probably use something like a black RTV gasket sealant.
Old 09-23-14, 12:20 PM
This product was recommended on a website I just came across detailing how to remove, clean, and reassemble the air box on a dirt bike: Amazon.com: 3M 08008 Black Super Weatherstrip Adhesive Tube - 5 oz.: Automotive
or...http://www.permatex.com/products-2/p...sealant-detail should do the trick (as recommended by Gunguy45).
Old 09-23-14, 03:55 PM
Gunguy45's Avatar
Super Moderator
The second one is close to what I would use, but I use the high temp gasket maker. It resists gas and oil if that's any sort of an issue in the location you need it. Gasket Makers : Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker
Old 09-23-14, 05:57 PM
I have and use the black weatherstrip adhesive all the time ...... great stuff but the silicone is definitely a better choice here.
Old 09-24-14, 06:18 AM
The Permatex website says the Black Silicone adhesive sealant resists oil as well so it sounds like it will be okay. Keep in mind whatever product I use must not only seal the screen to the box but secure it to the box as well (there are no screws), which is why a product with the word "adhesive" in it seems like the way to go.
