1994 ski-doo mach z 800
steve 567's Avatar
CT
11-16-14, 05:24 PM   #1
I NEED HELP
I have a 1994 ski-doo mach z 800 first i was getting way to much oil and no gas so i replaced all fuel lines rebuild fuel pump . removed and cleaned the carbs new plugs i can only get the machine to run for 2to3 seconds only by putting gas into cylinders also i disconnecting the oil line temperaily and mixing the gas. when i remove carbs they don't have any gas in them I know this is alot but i sure use some HELP thanks
goldstar's Avatar
OH
11-16-14, 05:49 PM   #2
Check that the fuel pump is working. Start with the fuse and go from there.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
steve 567's Avatar
CT
11-17-14, 06:47 PM   #3
thanks goldstar I am feeling good that pump is working i going to pull the carbs and double check the needles and everything else inside. Must be gummed up. Will let you know.
