Carburetor Assembly
Old 01-06-15, 01:18 PM
Carburetor Assembly
I'll be removing, completely disassembling and cleaning the carb off my '07 Honda CRF250X dirt bike and am looking for some advice on the proper way to reassemble it. Specifically, whether I should use a di-electric grease (e.g. CRC Technician Grade Dielectric grease) on the o-rings, throttle slide, jet threads, or any other parts. I'm pretty clueless when it comes to greases and lubricants as far as when and where to use which kind and where not to. Putting everything back together dry doesn't seem like a good idea.
Old 01-06-15, 02:45 PM
Temporarily Suspended
I would ask the manufacturer, of the carb. Nothing is better than info from the horse's mouth. May I ask, what's the reason for the rebuild?
Old 01-06-15, 03:11 PM
I've never used any grease when rebuilding a carb BUT I've never rebuilt one that new [complicated] either.
Old 01-06-15, 03:25 PM
Same here marksr, I never used grease either.
Old 01-06-15, 03:46 PM
There is no need for any form of grease in a carb.
Dielectric is for electrical connections.
Old 01-06-15, 05:35 PM
If you feel that you must do a total teardown, I would recommend taking pictures of each step and also notes on the procedure. This is not your old one barrel Rochester carb.
Old 01-06-15, 06:56 PM
Why am I doing it? Because I just bought the bike and it isn't idling without the choke, so I'll be tearing it down, cleaning the carb body and jets thoroughly, and replacing all the gaskets and o-rings (already bought the gasket kit). I'm also installing a different main jet and needle to richen things up (Hondas are notorious for coming lean from the factory). I won't use any grease then. I was searching around online and heard of others using a silicone grease on the slide and o-rings. Another site said to use a dab of petroleum jelly on the choke plunger for smooth operation. Is there no truth to these things?
Old 01-06-15, 07:09 PM
I could understand lubricating moving parts. That's about it.
Old 01-06-15, 07:24 PM
Gunguy45's Avatar
Super Moderator
I've rebuilt plenty of carbs (not as a Pro) and never did anything more than maybe a shot of WD40 or silicone to get something to slide into place.
The mechanical parts are better off just being thoroughly cleaned. Thats why they put bushings and bearings where needed.
Old 01-07-15, 11:57 AM
And what about the rollers on the throttle valve? No lube on those either?
Old 01-09-15, 09:43 PM
I just got the carb off the bike and removed the float bowl and jets. Since the bike wouldn't idle without either the choke on or the throttle screw turned in substantially, I expected to see a clogged pilot jet. However, all the jets are clear. What else other than a clogged pilot would cause this? Maybe the float isn't set high enough? I haven't measured it yet, but will do so tomorrow. BTW, it's a 37 mm Keihin FCR carburetor.
Old 01-12-15, 08:31 PM
I would run a compression check---could very well be leaking valves.
Old 01-13-15, 07:03 AM
I'll definitely be doing a leak-down test.
Old 01-13-15, 08:24 AM
The service manual says to inspect the throttle valve plate for scratches or wear. Mine looks a little worn towards the bottom and the black finish wearing off. I scraped the plate with my finger and pieces were flaking off. Should I replace it?
Old 01-14-15, 06:30 AM
It doesn't look bad but Mikuni and Keihin flat-slide carbs are pretty cheap online. If running a tag wire through the jets and spray cleaner through every orifice doesn't fix the idle IMHO I would replace it. Odds are good the wire & spray is all it needs.
I don't recall any of the 2-stroke carbs I've rebuilt as having a coating on the slide--but then my experience only goes up to 24mm. I think it's just carbon you're seeing.
Old 01-14-15, 08:59 AM
Well I went ahead and ordered a new valve plate just to be safe. Cost me $68, which seems outrageous, but that's the cost for piece-of-mind I suppose.
Old 01-14-15, 07:54 PM
I just picked at the valve plate again and it definitely looks like the finish peeling off, not carbon. Carbon wouldn't flake off in tiny squares. Good thing I'm replacing it.
Old 01-17-15, 03:22 PM
Just finished a leak down test. Only 4% leakage!!! Valve clearances are all in spec, so the engine is in great condition. I'm a happy camper.
