1999 yahama utility cart
Old 03-23-15, 07:30 PM
My 1999 yamaha utility cart won't start. I've been told the spark should be blue, I'm getting more of a reddish color. Also
If I wanted to check the igniter coil, where is it located? Any help is greatly appreciated.
Old 03-24-15, 06:51 AM
When in doubt I usually suspect the carburetor or fuel system before ignition or compression. Especially since you're posting your question in early spring... probably after the cart has sat through winter without being used much.
Old 03-24-15, 12:05 PM
Here is a link to the owner's manual. Take care of the suggested maintainance items and your cart will take care of you.
BTW Welcome to the forums.
https://yamahagolfcar.com/download/1..._-_G11_Gas.pdf
