Melex 112 Charger Connection
NCMau's Avatar
04-02-16, 06:12 AM   #1
The pic shows the bottom of the on-board charger receptacle. Is it where it connects to the batteries? It seems like a little puny screw (slightly larger than 1/8") for the amperage that the charger puts out.
Pilot Dane's Avatar
NC
04-02-16, 03:08 PM   #2
OK... Do you have a question we can help you with?
And, since you didn't say. I think you are referring to the charging connector for a golf cart. While a golf cart motor can draw tremendous amperage the charging is at a much lower rate which is why charging takes a long time.
NCMau's Avatar
04-10-16, 07:07 AM   #3
Sorry it was not clear...The question was in the text..."Is it where it connects to the batteries?" I realize it was a simple question, since I got this cart in pieces, I just wanted to be sure. Now the cart is all newly rewired, new batteries and it's running great. The only problem I have is the PW charger which came with the cart. I am in the process of troubleshooting it and I probably will have some questions later. Thanks for the help.
