Carb help please
Old 07-24-16, 09:48 PM
Carb help please
I have a 1994 dr350se Can I put a mikuni vm 32-33 carb on it and will it run fine? thanks in advance
Old 07-25-16, 03:44 PM
chandler's Avatar
We have no idea where you are located and few on the forum would know what a dr350se is to begin with, much less a mikuni vc 32-33, some clarification would really help. Remember, this is primarily a North American forum, so advice on other countries may be skimpy.
Old 07-25-16, 06:24 PM
A 32 mm carb on a 350 should work OK. You may have to do a little jetting work. It depends what you want to get out of it as far as performance. If you need max out of it you'll want to keep a check on the plug and throttle response as you go along.
That is a very good carburetor. They used the 36 mm single carb version of it on the 750/850 Nortons to replace the OEM Amals. It was a huge improvement.
