Ezgo golf cart will not charge
Old 05-29-17, 08:57 AM
K
My electric ezgo golf cart will not charge. My batteries are full of water.Is there a fuse in the charger?
Old 05-29-17, 09:06 AM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
Ezgo has used many different chargers.
Without a model number we would have to guess if it had a fuse in it.
The batteries being full of water doesn't mean that they are automatically good.
You could have a defective battery or connection.
You're going to need a volt meter to test the charger and batteries.
Old 05-29-17, 12:55 PM
P
Received 620 Votes on 573 Posts
How do you know the batteries are not charging?
Did this problem start suddenly? Did anything happen to cause it like driving the cart into a pond or was someone trying to "fix" it?
Old 05-29-17, 03:36 PM
K
Electric ezgo golf cart won't charge
The charger is isn't showing a charge on it. It hasn't been in pond or anything like that. My 80yr mom drives it in our small town and keeps it in a shed
Old 05-29-17, 03:39 PM
Does the charger have a power light on it ?
K
Ezgo won't charge
It quit on my mom coming from town.
Old 05-29-17, 03:52 PM
There are many things that can cause a problem.
Defective charger.
Broken wire in charger to cart cord.
Broken/loose charge jack on cart.
Broken wire from charge jack to batteries.
You haven't given us anything to go on so we have to guess at the problem.
You ARE going to need a test meter unless you have a second charger to try.
Old 05-29-17, 04:07 PM
K
Thank you. I'll look take a look at charder for fuse or broken wire. I'm not at mom's to get model #
Old 05-30-17, 05:33 AM
P
Yes, the first step is to determine if the charger is bad or if something happened in the cart.
How did the cart die? Did it just totally die suddenly or did is go slower and slower until it stopped?
