Kawasaki fh680d engine getting gasoline in the oil
Old 11-30-17, 07:07 AM
I have a 2007 bobcat 2200 utility vehicle with a Kawasaki 23 hp engine. The engine is a FH680d - As09. I am getting fuel in the oil and assume the carburetor is the culprit, The way the carburetor is situated looks very unfamiliar to me. I have worked on car and motorcycle engines in the past but this configuration has me uncertain Id I want to tackle rebuilding the carburetor.Also when I look for parts for the unit all sites ask for the engine number which is AS09-R, however the choices only go to AS08?
Has anyone been in this situation and what did you do? Thanks in advance. Scott
Old 11-30-17, 07:16 AM
Upvotes Received: 2
Old 11-30-17, 07:28 AM
How would gas get into the oil if there weren't a blown gasket or a crack somewhere?
Old 11-30-17, 07:50 AM
Upvotes Received: 140
If the carburetor float valve is leaking liquid fuel can dribble into the engine, down into the cylinder and seep past the rings into the oil below.
Old 11-30-17, 11:19 AM
The OP didn't mention any leaks.
Old 11-30-17, 11:38 AM
Upvotes Received: 2
The leak could be inside the carb throat, then down into the combustion chamber. It wouldn't necessarily be noticeable on the outside.
Old 11-30-17, 11:41 AM
OK, I'll wait for the OP to respond.
Old 12-01-17, 05:52 AM
Thank you all. I am new to the forum and not sure what I am doing. The are no signs of leaks only internal. Sounds like I need to rebuild the carb.
