2006 Club Car Carryall 1 48 volt. Mobilizing issue
I am having a problem with the 48 volt, 2006 club car carryall 1. The batteries are fuel charged. I was backing out and the cart traveled about 10' and shut down. No power. I pushed it forward and plugged the charger in. The charger did not come on. I waited awhile, check cables, connection, fuses. And I tried again. Again the cart moved about 10' in reverse and shut down. Any help will be appreciated on this troubleshoot. Thanks in advance.
Welcome to the forums.
You have an open connection between batteries. The batteries are in series and one bad connection will render the entire cart dead. They connections may look good but need to be checked with a voltmeter.
