Using 4 and 6 gauge connectors for golf cart
Old 07-27-20, 08:55 AM
B
I ordered some new 4 gauge connectors but could only get 1 set ( I needed 2) as they are back ordered. Can I connect the new 4 gauge and use with the old 6 gauge until I get the other set?
Old 07-27-20, 08:25 PM
Received 938 Votes on 875 Posts
Sorry..... I'm not quite sure what you are asking.
Not sure in this case what a #4 or #6 gauge connector is.
Quick connect plug ? Lugs ?
A picture or link would be helpful....... How-to-insert-pictures.
Old 07-28-20, 08:00 AM
B
The gauge of the wire. I have interconnect cables for the golf cartís 48v system - 8 6v batteries - and have some connectors that are made with 4 gauge wire and some with 6 gauge.
Old 07-28-20, 09:17 AM
P
Received 534 Votes on 491 Posts
Whether it's OK or not depends on the current draw. If you've upgraded the motor & controller and are drawing more current than stock then you may need the extras size of #4. If you your cart has the original drive system and originally had #6 then using #6 would be OK if everything is in good condition.
Old 07-28-20, 08:49 PM
You could use the # 6 cables temporarily but you'd definitely be better off with all # 4 cables.
Keep in mind...... a chain is only as strong as its weakest link.
Using any # 6 cables pretty much negates the benefit of using of # 4 cables in the system.
