Propane or Charcoal Smoker?
I just wondering witch one is better? any feedback is very welcome.
Thank you!
Thank you!
You will probably hear a lot in favor of one or the other, but I personally can't say I have a preference. In fact, I use my Geo. Foreman grill more than anything, but do own a charcoal grill that rarely gets used except by my brother-in-law.
If you enjoy a truly smokey flavor to your foods then I would recommend a charcoal grill. If you just enjoy cooking out and love grilled foods, then a propane grill would be perfect.
If you opt for a propane grill and want the smoke taste to a certain food, then add a little liquid smoke. Just remember, a little liquid smoke goes a long way!
Kay
Kay
Received 0 Votes
a grill usually has the fire under the food and cooks pretty fast. a smoker has the fire box on the side and cooks very slow such as when cooking a brisket. the side cooker aliows the heat and the smoke to draft through the cooking area leaving the smoke flavor in the meat.
Received 0 Votes
I would say that if you are asking the question...propane or charcoal for a smoker...it sounds like you may be a rookie from the getgo. I advise a propane grill 'cause you probably wouldn't get enough use out of a smoker. It is a sort of art and some science. You gotta light a fire and keep it at a fairly constant temp for several hours if not all day. On top of that, you would use real wood for a smoker. Pecan, citrus, mesquite maybe oak or hickory on occasion. Some science, the wrong wood burning makes the food taste BAD. For instance...chix with citrus wood or beef with a hickory. Get a book on the subject.
i think you mean grill...
I have to agree with Guiness... I think you meant to ask which is better between propane and charcoal grills. Do you want to be able to whip out some grilled hot dogs and hamburgers in an hour or are you going to be cooking beef briscuits and pork shoulders over periods of 10+ hours? I'd recommend that when you go shopping, ask to look at grills. Like someone already said, some people swear up and down by one or the other, but both have advantages, and it's really tough if not impossible to argue that one is clearly better than the other when it comes to propane or charcoal. I like charcoal, but only because I love the smell of burning coals in a grill!
good luck!
good luck!
by a combo unit.. I still like the charcoal and real wood method of grilling, bbq'ing, or smoking.. a little more work, but the end result is well worth it.. and with a combo, you get the best of both worlds, a grill and/or smoker...
I finally noticed when this was originally posted.. guess these things don't purge themselves after a set time?.. well, by now the other one is well broke in, so what did he finally get?...
Thank you!
Thank you!
Originally Posted by frhrwa
I don't think thats smoking tho..? smoking is below 170 degrees, kippering is above, and b-b-q.. that's above that...
under Pork Butt - The Renowned Mr. Brown:
Here are some pork butt photos I took on October 3, 1999 when I prepared the "The Renowned Mr. Brown" recipe from the classic book "Smoke & Spice" by Cheryl Alters Jamison and Bill Jamison. This is one of my favorite recipes for pork butt, and if you haven't tried it yet, you should!
My plan was to cook at 250°F to an internal temperature of 170-180°F, as called for in the recipe. (Most people feel that pork butt should be cooked to an internal temp of 170-185°F for sliced pork and 190-205°F for pulled pork. Choose your temperature accordingly.)
Under Baby Back Ribs:
Cook ribs at 225°F for 3 hours, turn slabs, then increase cooker temp to 250-275°F and cook an additional 1-2 hours until done.
I'm sure there are times when I will want a lower temp, but with my flame nob a hair above medium the temp is about 250. I think making jerky takes temps around 180 or so.
The meat still has to cook.
guess that's the difference that "time" makes... it takes time to do a cold smoke.. smoke houses leave the meat in the hanger for a long time, they don't just put it in and take it out in a few hours.. that's cookin with smoke added..
