bbq gas line
Received 0 Votes
bbq gas line
I recently bought a bank owned home. There was a bbq island but the grill was removed. The sink and everything works but no bbq.
I purchased a drop in Natural Gas grill to install in the BBQ island. There is a natural gas line with a yellow shut off valve attached inside the island. I installed the BBQ and connected everything but there is not any gas. The valve is on. There is a fire pit close by to the bbq island. It has signs of usage but appears to be missing the fire ring so I can't test it.
Is it possible the bbq island had a propane line and the gas line inside of it was to connect the propane to the fire pit? Would the natural gas hose fit a propane line?
Received 0 Votes
Do you have a gas meter in your yard? If you just purchased the house, you will likely have to pay a deposit before they unlock the valve & turn it on.
If it was using propane some one may have taken the supply bottle.
Received 0 Votes
Yes we have a gas meter. All the natural gas house appliances are working fine.
I was able to connect the the "hose" and it fit perfectly
so that makes me think it might be natural gas which is what I'm hoping for.
Thanks again
Thanks again
