building an outdoor kitchen
Received 0 Votes
I want to build a steel frame outdoor kitchen. Do I make the frame with supports at 16 inches or does it matter?
Welcome to the forums! Why steel? Remember "outdoors" means moisture means rust means boo boo.
Why not go ahead and use a block or concrete foundation, then pressure treated framing, covered with concrete backer underlayment and tile on that. We do it a lot here. Will it be covered, closed in, etc?
Oh, OK, steel "studs", I can see it. I was thinking of a welded steel frame that would be a bear to build. Start with the steel channel to put the studs in (top and bottom), use 1/2" self drilling screws. It's up to you as to the design of the kitchen. 16" oc would be a minimum on the steel studs. You could, then, install one stud at the intersection of the cbu (which is 3' x 5'), and screw the cbu to the steel studs. After that, thinset and tape the joints and install tile or rock at your desire. I would do a combination of rock on the side with a tile top. Let us know if you need more help or if this was no help at all.
