Engine Question
Old 08-10-02, 06:01 AM
indianajohn
Briggs&straton V16 Twin
I would like to know where I can find the engine bolt torque specs on the b&s V16 twin without having to buy a manual. Thanks John
Old 08-10-02, 12:37 PM
You have the numbers from the engine?
Old 08-10-02, 12:41 PM
indianajohn
briggs v 16 twin numbers
model number 303777 type 0332-01 code 92110511 1880
Old 08-11-02, 05:52 PM
Joe_F
Not wanting to buy a manual is like trying to take a college course without the textbook. Inherently it is more difficult that way .
I suggest the local library. Most have the 1998 publication of the Briggs and Stratton manual which is a great basic book and should have what you want in it.
Old 08-12-02, 09:48 PM
John,
I don't have the manual on your particular engine but on similar Briggs is listing as follows;
Aluminum
Head Bolts 165 in. lbs.
Conn Rod 185 in lbs.
Flywheel 65 ft lbs
Cast Iron
Head Bolts 190 in lbs
Conn Rod 190 in lbs
Flywheel 145 ft lbs (looks awfully high to me)
Hope this helps.
Old 08-13-02, 06:25 AM
indianajohn
Thanks for the information. That's all I needed to know because all I am doing is replacing the head gaskets.
