Engine Starting Problem
Old 09-01-02, 09:06 AM
adkne07
Unhappy briggs & Stratton lawnmower
I just completed changing oil and cleaning carburator, air cleaner and spark plug. I mowed a couple of strips (it was running fine) then all of a sudden it quit and I cannot get it started again. I even let it set for a day and tried again , no luck. Any suggestions? thanks for your time
Old 09-02-02, 10:03 AM
Sharp Advice's Avatar
Admin Emeritus
Several Possibilities
Hello adkne07. Welcome to our Small Engine forum.
There could be several possibilities for that condition.
Could be simply a defective spark plug, no spark at the plug due to a lack of ignition, etc. Could be the kill switch is grounded, rusted, etc.
You'll need to check for spark and replace the plug, if needed.
Possible there is some debris in the fuel line or within the carb restrciting or blocking fuel flow to the carb or into the carb. Check for fuel flow into the carb by removing the fuel hose at the carb.
Vent air inlet hole {breather vent} hole in the fuel tanks cap could be blocked or restricted. Try starting the engine without the fuel cap on the tank.
Most likely I have not covered all of the potential possibilities. The other resident small engine service and repair professionals may offer additional suggestions, advice & help.
Check back on your topic several times over the next several days for additional replies.
In the mean time:
You need to read the other postings and replies offered on this same type of engine problem topic in the RECENT & ARCHIVES postings, within this forum, for additional help & information on this subject.
If you need further assistance, use the REPLY button to add any additional information or ask another question on this same topic, etc. Using the above method also moves the topic back up to the top of the list automatically.
Regards & Good Luck,
Tom_B
Small Engine Forum Host & Moderator
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
