Engine Starting Problem
Old 09-01-02, 05:21 PM
DCDoug
Motor stuck, Honda Power Washer
Honda GC610 Power Washer. Just out of warrenty.
I have been using it recently, about 30 hrs in the last 3 weeks with no problem. Tried to start it today and it would run for 30 to 90 seconds and quit. Did this about 3 to 5 times. Then on last try, when I pulled the starter string, it snaped, (maybe I lost grasp on the return). After that, the starter string won't pull, it stops (jams). Took off the housing around the starter string and could not turn the motor by hand. The sting assembly seemed fine.
What is the best way to free up the bind? Can I do it? Can a small engine repair shop do it quickly and cheaply?
It has oil, but not been changed. I have to store it outside, but covered up in plastic. We have had a lot of rain lately. Maybe this has something to do with it.
Great Site! I just discovered it!
Peace,
DCDoug
Old 09-02-02, 10:13 AM
Sharp Advice's Avatar
Admin Emeritus
Several Possibilities
Hello and Welcome DCDoug to our Do-It-Yourself Web Site and our Small Engine forum.
In my opinion, covering the equipment with plastic isn't a good method. Plastic does not breath so it tends to hold in the moisture.
Moisture on most parts will create rust and corrosion. Corrosion on the electrical componets and in the fuel system, etc. can cause the problem you described and many other similar problems.
It's also possible the vent hole in the fuel tanks cap is restricted and or blocked up. Try running the engine without the cap installed.
Also check for fuel flow out of the tank and into the carb. Carb could be filled with water, gum varnish etc. or just plugged up with gunk. Float could be stuck etc.
The other resident small engine service and repair professionals may offer additional suggestions, advice & help.
Check back on your topic several times over the next several days for additional replies.
In the mean time:
You need to read the other postings and replies offered on this same type of problem topic in the RECENT & ARCHIVES postings, within this forum, for additional help & information on this subject.
If you need further assistance, use the REPLY button to add any additional information or ask another question on this same topic, etc. Using the above method also moves the topic back up to the top of the list automatically.
Regards & Good Luck,
Tom_B
Small Engine Forum Host & Moderator
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
