Lawn Mower Fuel Leak
Old 09-07-02, 08:23 AM
alynn
Briggs & Stratton
I have a walk behind lawnmower with a B & S engine. The problem is this:
When I fill the gas tank, the gas leaks out through the primer button.
Is this something that I can fix or do I need to take it to the repair shop?
Thanks, Lynn
Old 09-07-02, 12:03 PM
J A Boggan
Lynn,
There are two tabs at the bottom of the primer bulb that have to be pressed inward at the same time. Then get a new bulb (if the old one is leaking) and reverse the procedure. They make a couple of tools for this (which make the job very simple), however I believe I would just try and 'worry' it back on.
