Head bolt torque spec
Old 09-10-02, 11:59 PM
Rhodes Wilk
Lightbulb Head bolt torque spec
I am currently overhauling an 8 HP Briggs and Straton engine that is operating on a Troy-Built "Horse" Tiller. Can anyone tell me what the head bolts should be torqued to (FT.LB.)?
Old 09-11-02, 12:24 AM
cheese's Avatar
Received 22 Votes on 19 Posts
Hello Rhodes!
If it is an aluminum cylinder, the torque is 165 in. lbs.
If it is a cast iron cylinder, the torque is 190 in. lbs.
This is for a model 19xxxx model engine, which is an 8hp. The 1st 2 numbers must be 19.
Hope this helps!
Old 09-11-02, 12:00 PM
Rhodes Wilk
head bolt torque specs
Thanks cheese! That will help.
