String Trimmer Question
Old 09-28-02, 02:20 PM
J A Boggan
Question String trimmer string
Is there any (foolproof) way to wind the string so that it won't get caught and 'not' feed the string whenever you bump the spool on the ground?
Old 09-29-02, 05:25 AM
mikejmerritt
Hello J A Boggan, line welding is pain and sometimes can't be overcome but here are a couple of thoughts. There are 4 shapes of line so you may try one that you are not using. Round hangs the most but there is 6 sided, star shaped (Oregon Grass Chain) and sqaure (Square Cut makes a good one). Try not to wind the line to tight on the spool because it tightens as you run the trimmer anyway. Last resort.....As you wind the line spray some PAM on the spool and line a couple of times. I bet it will come out of there then.....Mike
Old 09-29-02, 06:41 AM
J A Boggan
Mike,
Thanks again for the information.
Jack B.
Trackbacks are On
Pingbacks are On
Refbacks are On
