Engine Question
Old 10-11-02, 09:28 AM
Z
zio
cracked crankcase coveer
I have a Briggs & Stratton 8HP engine (mod. 190432, type 5163) that has some small cracks on the bottom of the crankcase cover and leaks oil. The cover is non-magnetic and probably aluminum or some alloy. Short of buying a new cover, are there any suggestions for repairing these cracks?
Old 10-11-02, 02:31 PM
D
dave4.3
It can be welded or try JB weld (metal glue). I used the Locktit version of JB to glue a fin on a flywheel back on. It works!
Old 10-11-02, 07:45 PM
cheese's Avatar
Received 31 Votes on 26 Posts
Hello zio!
I would suggest replacing it, but a welding or machine shop should be able to weld it. Welding it might cause a little warpage though, so be careful to check that everything fits correctly when re-installing it. JB weld might work in this application as well. I would definitely not use any glue to hold a fin on a flywheel though. At 3000 rpm, I don't trust any glue.
