Snowblower won't start
Old 11-05-02, 05:01 PM
D
I have a Snow King SC 522 snowblower with an HS 50 Tecumseh engine. I am unable to start the engine. I checked and found a small amount of gas in the tank. I usually run it dry in the spring, it must have quit running with the gas in the tank. I'm guessing the gas gummed up the carburator. Can I disassemble the cover and clean the carburator with a spray cleaner?
I have put fresh gas in and it won't start. I'm going to get a new plug also. I'll check the spark if the cleaning and new plug don't help.
Thanks,
Sherm
Old 11-05-02, 10:58 PM
cheese's Avatar
Received 31 Votes on 26 Posts
Hello Dsherm!
You should be able to disassemble the carb and clean it just fine with spray carb-cleaner. You may need to replace the diaphragm and gasket when you do. Let us know how it goes!
Old 11-06-02, 09:38 AM
racket7's Avatar
Snowblower start stuff.....
I picked up a junker Ariens and swished the tank with starter spray and dumped it out. I noticed that it had a stainless screen inside so non of the rust could get to the carb. I put a new plug in and used a bike pump to force air through the carb with the bottom screw removed. Looked like solidified honey and dirt that came out but then a stream or air. Capped it, wd40'd the "rusted solid carb controls" and gave it fresh gas and it runs great. You might just blow the carb out..... worked 4 me.
Old 11-06-02, 11:28 AM
D
To Racket 7,
I'll give your suggestion a try. I have an electric pump to use. My snow blower is also sold as an Arien's. Actually, it's made by Noma, I think they make most of the store brands.
I assume you blew the carb out on the machine right? You didn't remove it.
Thanks,
Sherm
