11-29-02, 08:12 AM
ringoryan8
JB Weld
I have a briggs 3hp carb and it is cracked near where the carb mounts to the engine. Has anyone ever tryed JB weld or another kind of instant weld to repair a cracked carb?
CAL
11-29-02, 11:48 AM
Hello: ringoryan8
Depending upon what you mean specifically by "it."
If you're refering to the mounting area on the carb body where the securing bolt secures the carb to the engine, a welding adhesive may or may not work. But may be worth a try.
If "it" means any part on the engine, an adhesive will not work. Too many factors like heat, vibrations, etc. will effect the adhesive and the problem will return.
The only likely solution would be to buy a used carb from a local small engine shop or lawn mower repair store. Once you have that you can transfer the internal parts from the broken carb into the replacement carb, if needed.
Be sure to replace all gaskets for any repair or part replacement made. Be careful not overtighten any screws, securing bolts or nuts.
The other resident small engine service and repair professionals may offer additional suggestions, advice & help.
Check back on your topic several times over the next several days for additional replies.
If you need further assistance, use the REPLY button. Using the reply button moves the topic back up to the top of the daily topic list automatically.
Regards & Good Luck. Tom_B.
Web Site Host & Small Engine Forum Moderator
"Accurate Power Equipment Company"
Small Engine Diagnostics Services and Repair.
11-29-02, 02:02 PM
ringoryan8
its only a crack so I am going to JB weld it. it didn't break off completely though. its just an air leak
GA
12-01-02, 12:58 AM
Hello ringoryan8!
If you use the JB weld, make sure you clean the area well and rough the area up a bit with some 60 grit sandpaper to promote good adhesion to the area. For just a crack in the carb you'll probably be ok to fix it with JB weld. Try to work it into the crack as well as over it.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
