Carb Problem
Old 12-14-02, 01:51 PM
GregH's Avatar
Super Moderator
Question Tecumseh carb float.
Equipment details:
Coleman 5 kw generator.
Engine: Tecumseh 10 hp, mod- HM100 159232K, S/N- 20900
Carb: mod- 107402M
After cleaning the carb for starting the engine after an extended lay-up, I experienced fuel running out of the carb.
I took the carb apart again to adjust the brass float and found it to have fluid in it.
I polished it with steel wool and cannot detect any cracks or corrosion.
Should I be looking harder, or does this float use a liquid as ballast?
Old 12-14-02, 03:51 PM
Joe_F
If you can hear fluid sloshing around in it, pitch it. It's taking on fuel---that's the cause of your problem.
Sometimes the seams split or the solder joints get porous and the fuel seeps in there.
Most Tecumseh floats are shaped kinda like a toilet seat and should be readily available just about anywhere .
Old 12-14-02, 06:37 PM
Tcumcman
Float Problem
As Joe has very adequately covered, you need a new float and
this is a VERY POPULAR part to locate. ANY Dealer should have
one in stock. Part # 632019.
Tcumcman
Old 12-14-02, 11:36 PM
cheese's Avatar
I agree. Thanks guys!
Old 12-15-02, 05:54 AM
GregH's Avatar
Super Moderator
Thumbs up
Thanks guys, I'll be heading to the big city for Christmas and I'll pick one up.
Thanks again.
