wrong gas mixture used
Deweydoggg's Avatar
02-05-03, 05:03 AM   #1
Deweydoggg
Reg. unleaded gas was run through my 2 cylce engine snowblower, and it quit running. Is the motor now completly shot or is their something I can do at home without alot of repair costs? I have minimal experiance in this, but I enjoy tinckering with projects.
Thanks for your help, anyone.
J A Boggan's Avatar
02-05-03, 06:05 AM   #2
J A Boggan
Are you saying that you ran it without oil? If so, is the engine seized up? If it is, I would take the engine apart and look at the piston and cylinder closely. If the cylinder is scored up bad...it may not be economical to repair.
Deweydoggg's Avatar
02-05-03, 07:08 AM   #3
Deweydoggg
Yes the gas the person used did not have oil mixed into it and I do believed the engine siezed up. I take it apart and check the piston. Thanks
MikeMoore's Avatar
02-11-03, 01:45 PM   #4
MikeMoore
Fix it!
Most of the time you will scare the cylinder and lock your rings up with no oil in your gas. Try this before tearing your engine apart; remove spark plug. Fill cylinder with 2-cycle or kerosene. Install spark plug. Allow to set for minimum of two days. Remove recoil and spark plug. Apply wrench to flywheel nut. Turn very slowly; after kerosene has ran out of cylinder fill with 2-cycle gas. continue to turn flywheel until piston moves freely. If you have a chrome cylinder this should correct the problem. This works for me at a inimum expense.
Deweydoggg's Avatar
02-13-03, 09:00 AM   #5
Deweydoggg
Thanks I'll give it a shot.
