Starting Problem
honda power washer
i have a honda power washer 5.0 hp the last time i used it was in the spring last year and when i put it up i filled the tank up with gas and added a fuel stabilizer per instrustions. now i went to start it today and it would not start. should i try draining the tank and putting fresh gas in or what?
Hello Ripperdog3!
First, make sure you have spark at the plug.
If so, drop a few drops of gas into the spark plug hole and try to start. If it runs for a second and dies, then remove the carburetor and clean it well.
Let us know what you find!
good news took carb. out of soak today blew it out real good put it back together and back on power washer , filled tank with new gas fired right up purring like a kitten, washed my four wheeler then put stabilizer in tank and crossed my fingers hope it fire up next time. thanks for all the help from everyone
