Starting Problem
Old 02-11-03, 08:55 AM
jbg1990
B&S 6.0 Sears Craftman Mower/Starting Problem
I changed the spark plug and put in clean fresh gas and my mower still won't start. My next step, I guess, should be to look at and clean the filter? Anything else that could cause this?
Any help and suggestions will be appreciated. Thanks.
Old 02-11-03, 10:08 AM
Joe_F
Do you have spark? Is there fuel getting to the carb?
Squirt a little fuel into the spark plug hole. If it fires, runs for a few seconds and dies, a classic fuel problem.
Old 02-11-03, 10:34 AM
jbg1990
Thanks, Joe_F, for your reply. I will go to the site you recommended. I'll save it.
Took top/cover off and cleaned up that area a bit (wasn't that dirty) and then used yet another spark plug.....Mover STARTED! I'm not sure which did it.
I hesitated lifting my hand off the bar for fear I might never get it started again, but the cover had to be put back on. After doing that...it started.
Again thanks.
Trackbacks are On
Pingbacks are On
Refbacks are On
