Hard starting snowblower
I have a John Deere 26 inch snowblower powered by a 8 horsepower Tecumseh snow king engine. To get it to start, I have to put some gas down the spark plug hole; it will then start on the second or third pull and run fine. I changed the spark plug- same problem. What can I do to get it to start the normal way?
Hello GDon!
Does the engine have a choke? If so, it is probably not closing all the way. Simple adjustment will take care of that. If it has a primer, it is not priming. This could be caused by a bad primer bulb or a bad bowl gasket.
Let us know what you find!
