can't pull the starter pulley
Old 02-18-03, 09:37 AM
AUSTEN
Unhappy can't pull the starter pulley
I own the MTD/ Tecumseh HSK600 snow blower. It was working this weekend, but when I ran into big chunk of snow, it just stopped. Normally, I can re-start with a tug of the pulley, but it did not work this time. It seems to be stuck. Is there a blown engine? How much will it cost to replace the engine - is it worth it? Thanks
Old 02-18-03, 12:40 PM
cheese's Avatar
Hello Austen!
Can you turn the engine from the shaft end with the belt/chain removed? If not, it's probably locked. A new HSK600 is cheap...$100.00 will get you one.
Old 02-18-03, 07:57 PM
rogerh's Avatar
If this is a direct drive snowblower there may be a rock or stick under the empeler causeing it to be locked up.
Old 02-19-03, 06:10 AM
AUSTEN
I removed the chain and belt from the engine and was able to turn the shaft. I can pull the starter pulley.Thanks a lot guys.
Austen
