Self propeller don,t work
Old 02-24-03, 06:41 AM
Guillermo velas
Hello again, I have a snapper lawnmower that the selfpropeller sometimes work and sometimes don't work. I think is one of the pulley or is the belt itself can you tell me which one of this one can go wrong thanks
Old 02-24-03, 09:00 AM
Joe_F
Model #? Age of equipment?
Old 02-24-03, 09:29 AM
D
Check the drive disk...Snapper is infamous for the drive discs wearing out...When I worked for a company that distributed Snapper, the drive disc was our most common part shipped. It is possible that your mower has both a "drive disc" and a "driven disc" You will have to take a model and possibly a serial number to your dealer.
On a second note, I have a self propelled Snapper mower...the "Anniversary Classic"...What a fantastic machine!!!
Old 02-25-03, 10:47 AM
MrWrench
We really need to know the model number of the machine to be sure. Snapper has had the same very simple self propell design for as long as I can rememeber. Usually there is an easy quick fix.
Drive belt, idler tension spring, worn drive disc, or improperly adjusted spring on engagement cable ( spring under black sheath).
Josh
Old 02-25-03, 12:42 PM
Joe_F
I'd bet this is a similar setup to my Murray/Sears snowblower with the disc for speeds .
