03-05-03, 08:26 AM
sprocket226
I received a Simplicity snow-buster 220 for free. It has no spark. I tried new plug, took the cover off, looked at the ignition, all looks OK. The engine is a little 2-stroke.
Is there a test I can do on the condenser and coil to see if they're ok? Like put an ohm meter on them and check for resistance?
Here is a pic of the ign.
pic
This is just alittle project to see if I can get it going, Thanks
pic
03-05-03, 07:04 PM
MrWrench
Hey Sprocket, Your Simplicity has a little 2 cycle Tecumseh engine. Probably an HSK600. Try changing the Points and the Condensor which are the same as the 4 cycle ignitions, you should be able to get them at any small engine shop. Make sure that you put the magneto back on exactly where it was before. you should have spark if you coil is still good.
Josh
Josh
03-05-03, 08:37 PM
sprocket226
I was thinking the same thing too. Must be bad coil...OK, thanks !
GA
03-06-03, 12:21 AM
Hi Sprocket!
Make sure your points are opening and closing, with a .020" gap at TDC, and check your kill wire to make sure it is not grounded. That system is a pain to set just right, but usually, if the coil is mounted exactly where it was (look at the marks on the bolt holes where it was mounted), and the points are set at .020", then you should be ok, if all components are good. I believe if you check for continuity between the wire that goes to the points, and the coil laminations, and you have no resistance, the coil is shorted.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
03-08-03, 06:11 AM
sprocket226
There are 3 wires connected to the post at the points, one is the kill switch, one goes to the condenser, the other goes to the coil. Is that right?
03-08-03, 03:20 PM
sprocket226
Tried it, no spark. Well I had to go to Walmart for dog food, took a stroll to lawn-mower dept. I bought a Techumseh tune up kit, (points and condensor and new plug) put it in, set the plug at .030 and the points at .020. WA-LA! nice blue spark! So I put it back together and now I have a little snow-blower for $11!
My wife thinks I'm nuts for wanting a couple of inches of snow tonight!
Thanks!
Thanks!
