Engine Starting Problem
Old 03-24-03, 06:16 AM
Jerry1
Honda HR 216 Lawn mower
My Honda HR 216 Has a Roto Stop lever. When I try to start the engine (pull start) the blade stays engaged. This will not allow the engine to pull thru clean loading the engine. does anyone know what ould be causing the blade to remain engaged?
control lever looks as though it is acuating the cable underneath the mower/ went to honda web site .....Useless. Any other sites?
Thank you to all responders.
Old 03-25-03, 05:27 PM
ALMOST
blade won't disengage
did ya look and see if there is a adjustment on this beast , maybe it is'nt pulling the disengagement back all the way , just a thught
Old 03-25-03, 10:30 PM
cheese's Avatar
That, or...the clutch under the engine is not disengaging due to rust or frozen cable.
Old 03-26-03, 04:58 AM
Jerry1
Thank you for your replies, I have had the cable all the way out slides thru the shroud fine. It does pull the spring loaded lever and the springs are present and appear to be working. How would I go about checking to see if the clutch is disengaging?
Bade turns when I try to start the engine. Due to this load the engine will not start.
Thank you again for any replies.
Perplexed in Indy
Old 03-26-03, 05:36 PM
ALMOST
unplug that spark plug and try adjusting the cable and give it a try well you are adjusting it , like another post said could be in the clutch it's self to , but try adjusting it again
Old 03-27-03, 12:33 AM
cheese's Avatar
That cluth has some ball bearings in it that roll between two plates to activate the blade. Sometimes these balls get rusted into position and keep the clutch from operating properly. Sometimes the clutch fiber disk just gets stuck to the plate, and a little pry with a screwdriver helps pop it loose.
Old 04-04-03, 04:46 AM
Jerry1
Thank you all for your infomative posts. It appears that this clutch is locked up..... How do I pull the clutch out of this Beast ?
Thanks again for the good info.
God Bless
Old 04-04-03, 10:51 PM
cheese's Avatar
Hmmm..been a while, but I have one in the shop right now that I have to remove, so I'll check, but I think you have to remove the blade, then remove 3 or 4 screws around the outside of the clutch to pull it apart. Try soaking it with some PBblaster or other good penetrating oil and tapping around the diameter of the clutch with it disengaged to get it to pop loose first.
