Mantis 2 cycle tiller
JustSid's Avatar
03-31-03, 10:59 AM   #1
JustSid
Hello everyone, I just found these forums. Very nice stuff here
Onto business.
I have a Mantis tiller, 2cycle engine, about 20 pounds. I really like this thing but I am having SO many problems getting it started. I know practically nothing about 2 cycle motors so is there anyone that can give me any hints?
To me the compression sounds good but it just doesn't "catch."
Here is what I have done:
1.) primed the carb by depressing the little bubble until it fills with gas
2.) closed off the air.
3.) Pull the cord.
It just won't turn over.
I have replaced the air filter and spark plug, and in the case of possible flooding I have removed the spark plug and let it air out for hours... It just won't start. It just had an overhaul last season also!
Thanks in advance if anyone knows.
Frustrated,
JustSid
cheese's Avatar
GA
03-31-03, 04:32 PM   #2
Hello JustSid!
Determine whether you have spark at the plug or not, then if you do, try squirting a bit of gas into the plug hole and start it. If it runs for a second or two, you have a fuel problem.
I am going to move this question to the small engines forum, where pros in the field will be more likely to see it.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
JustSid's Avatar
03-31-03, 06:06 PM   #3
JustSid
Thank you very much Cheese, I didn't see the small engine forums, sorry!
Yes there is spark... I pull the plug out and cranked it to find apsark between the plug and the chassis.
I am leaning more towards a fuel issue actually... After pulling ot for seemingly hours I get a sound like it almoist wants to catch but then stops... Tomorrow I am goingto clean out the fuel lines and see what happens with some new gas/oil fuel mixture... again, thank so much.
Almost there!
-JS
cheese's Avatar
GA
03-31-03, 06:10 PM   #4
Quote: "Yes there is spark... I pull the plug out and cranked it to find apsark between the plug and the chassis."
There must be a spark at the electrode in the plug. If it is sparking between the plug and the chassis, but not at the plug's electrode, you have a bad plug.
God bless!
JustSid's Avatar
04-01-03, 07:10 PM   #5
JustSid
Ok, did a MASS change of everything. Spark plug, air filter, gas.. all new...
Thing started like a champ.
SO being the geek I am I started putting old components back in until it failed.
Turns out that it was a combination of bad things. Yes the spark plug was bad but I also had some stale gas
Thanks Cheese, you da man!
-JS
cheese's Avatar
GA
04-01-03, 11:03 PM   #6
Anytime! Glad I could help.
God bless!
