Dies under load
bgilliam's Avatar
04-04-03, 04:08 PM   #1
bgilliam
Dies under load
I have a Sears Craftsman Trans-Axle Drive Eager-1 riding lawn mower. I have no idea about the history but it runs great at idle out of gear and on flat surfaces and declines while in gear. The problem is when I start an incline surface or engage the blades it bogs down and dies. To keep it from dying I have to hit the clutch quickly and move the throttle back down to a slow speed. When the mower is out of gear I can get the throttle very high but when in gear and/or under any load it will die at the same settings. Any information would be helpful as I have no idea about small engines.
Thanks much.
Fisher's Avatar
04-04-03, 07:31 PM   #2
Fisher
Post your mower's model numbers so we know what you have.
You may have a safety switch problem, which may be a switch
or a bare or loose wire. Once we know what you have, we can better help you.
Fish
bgilliam's Avatar
04-04-03, 07:34 PM   #3
bgilliam
This is the only number I can find on the engine 143-266022 ser-6149d
cheese's Avatar
GA
04-04-03, 10:44 PM   #4
Waht horsepower engine do you have? Brand engine? It sounds like the engine is leaning out, needing more fuel when placed under a load.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Fisher's Avatar
04-05-03, 12:30 AM   #5
Fisher
You have a Tecumseh engine, and my guess as to your
problem is that you have a layer of water in the carb, which
stays there until you move, jostle, or go on an incline, then
some of this water gets "slurped" into the engine.
Remove the bowl nut off of the bottom of the carb, and drop
the bowl down and look inside.
Fish
