tecumseh carb
Old 04-18-03, 07:30 PM
rlbing
tecumseh carb
Working on a Craftsman mower w/Tecumseh. I found all the answers to my questions here (great site) except for one simple one. What is the correct posistion for the float bowl? I see the bottom is offset, but did not notice what position it was in before I took it off. Does it matter?
Old 04-18-03, 09:31 PM
J A Boggan
rlbing,
The flat side of the bowl goes under the hinged portion of the float.
Old 04-18-03, 11:30 PM
cheese's Avatar
Yes, the deeper portion of the bowl goes under the end of the float that drops down.
Old 04-19-03, 05:18 AM
Tcumcman
Float Bowl Position
You'll also notice....the small dimple in the bottom of the
bowl on the deeper side....this is there so only this very
small area of contact touches the float which prevents
the float from possibly sticking to the bottom of the bowl
when gum/varnish residue is present in there when the
engines runs out of fuel. Make sense ??
T-Man
Old 04-20-03, 09:14 PM
cheese's Avatar
You know, I always wondered why tecumseh floats weren't designed with a tab to prevent the float from dropping all the way to the bottom, but I never have seen it cause a problem. (thanks to that dimple), lol!
