eager 1 5.5 hp will not start
scomike's Avatar
04-21-03, 03:57 PM   #1
I can pull the cord forever it seems and will not start.
When i pull the cord it snaps back sometimes and i'll hear a pop and some white smoke comes out of the exhaust and sometimes the air filter.
I know i dont have the trottle settings adjusted properly because I dont know what the settings are.
The mower has; new plug, new oil, new air filter.
the plug gets wet so it seems it is getting fuel.
any suggestions?
cheese's Avatar
GA
04-21-03, 08:08 PM   #2
Hello scomike!
Sounds to me like you have a sheared flywheel key. You will need to remove the flywheel to replace it. Check first to be sure your blade is not loose. Have you hit something like a root or brick with the blade recently?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
scomike's Avatar
04-21-03, 09:19 PM   #3
I have hit things in the past.
when i take off the shroud and look at the flywheel i cant see the flywheel key , should i be able to or do i have to remove the flywheel first?
scomike's Avatar
04-21-03, 11:18 PM   #4
Just took off the flywheel and guess what!! a sheared flywheel key !!!
I will get a replacement and report back when installed.
Oh , still don't know what the settings are for the throttle.
cheese's Avatar
GA
04-22-03, 11:52 PM   #5
Not sure what throttle settings you are trying to set...the cable? Idle speed?
God bless!
scomike's Avatar
04-23-03, 12:12 AM   #6
I put a new key in and the engine still does not want to start.
the cord kicks back and the engine does not want to kick in.
any suggestions ?
Joe_F's Avatar
04-23-03, 09:08 AM   #7
Joe_F
Do you have spark?
scomike's Avatar
04-23-03, 09:17 AM   #8
I have spark, and took the shroud off to make sure the key looks good and it does.
every seems ok , oh and i have the blade off, does that make a diffeerence?
rogerh's Avatar
04-23-03, 03:11 PM   #9
Yes the blade must be on and tight for the mower to run. The wieght of the blade acts like a flywheel. Have you had the blade off all along?
texdiyguy's Avatar
04-23-03, 03:44 PM   #10
texdiyguy
Memories of Carl in "Sling Blade".
scomike's Avatar
04-23-03, 07:35 PM   #11
Just want to say thanks ........... it was the flywheel key that fixed it.
I put the blade on and it started 1st time.
1995 model - fully tuned up and running fine.
cheese's Avatar
GA
04-23-03, 10:55 PM   #12
Yep...The blade acts as a flyweight to help keep the engines' momentum going around in the right direction. Without the blade, the engine will kick back, as you have seen.
Glad we could help!
God bless!
