String Trimmer Question
Old 04-28-03, 04:35 PM
Wino
Unhappy Stihl FS-80 Weed eater
Replaced carb,fuel lines,gaskets & fiberspacer,foam filter,gas cap,fuel filter assy,& in line primer.Starts right up,idles fine, low speed ok, acts like it runs out of gas when full throttle. Tried with cap off, same result but runs full throttle when I keep pumping the primer. Whats happening? TIA Rich
Old 04-28-03, 05:44 PM
cheese's Avatar
Received 146 Upvotes on 135 Posts
Hello Rich!
Try backing out the high speed screw on the carb about 1/4 turn or so. This should get it going. If not, you may need to clean the carb.
