shaky mower
Old 05-02-03, 09:09 AM
ahlecks
shaky mower
hi, there,guys.i need help.my lawn mower shakes/vibrates even the handles because of that.the leaves bag collector pops out.need your help.thank you
Old 05-02-03, 09:16 AM
the_tow_guy's Avatar
Two things:
1. Make sure every nut and bolt is tight.
2. Replace the blade; it may be bent or out of balance.
3. Have it professionally checked for something more serious like a bent shaft (from hitting something solid while mowing).
Old 05-02-03, 11:01 AM
jote7946
Mine vibrates also...My hands go numb from it! I changed the blade, tightned every bolt, made sure the front wheels and back wheels were set to the same height! It still virbrates.
Never checked for a bent shaft...sound exspensive
Do what I did...I got anti-vibration gloves...the type they use for Jack-hammers. They work great!!!
Cheaper than a new mower!!!
Old 05-02-03, 01:17 PM
Joe_F
Vibration can be dangerous. Parts can loosen and fly off or shear and cause injury or property damage.
Vibration is generally a sign of trouble. Your life is not worth saving on the repair or replacement of defective equipment/parts.
Old 05-03-03, 12:20 AM
cheese's Avatar
A bent shaft CAN be dangerous, as Joe mentioned. If the bolts are tight, and blade is not bent, you most likely have a bent crankshaft. This will ruin the engine at the least, because it wears out the bottom bushing and lets the oil out. A crankshaft should run somewhere around $40.00 for most push mower engines. Some shops straighten them.
