String Trimmer Question
wiring
how is a stihl weedeater wired? i get continuity with the run ,stop switch in either position.
Received 7 Upvotes
Moderators Request
Hello: Red Harris
I have merged both your questions into one single question.
Please use the Reply button to add additional questions or information pertaining to this machine.
In doing so, all additional questions and information remains within this thread.
Doing so makes it much easier for both the moderators and members posting replies or reading the question to follow along and learn from the information exchanged.
Your consideration in this matter will be much appreciated.
Thanks,
Web Host & Multiple Topics Moderator
Tom_B.
Thanks,
Tom_B.
Hello red!
With the wire disconnected from the coil, at the coil end, you should have continuity to ground when the switch is "off". You should show no continuity when the switch is "on".
