Hello,
Murray 21" walk behind w/self propelled. Briggs&Stratton engine. Unfortunately could not readily see any model stamp or serial#s. on the engine. However mower tag says model# 6-21981. Date of manuf. 3095. Gas is weeping out from carb. throat even when not running. Mower runs and will start on one pull. Dropped bowl to take a peek. What I assumed to be a float ( toiletseat shaped plastic )did not seem to be stuck . Thats the limit of my expertise. Can you please help me troubleshoot and correct the problem. Also if I need parts , can you determine the make and model of carb. from the mower model# and date of manuf. that I have provided.
Thanks,
Ken S.Read More
