Ring Gap Specification
Old 05-20-03, 04:42 PM
TrackerSD
I am working on a Tecumseh 4.5 Horse on a Craftsman Lawnmower, and I need the ring gap. I had to go to a .010 over piston. I usually don't work on lawnmowers and I really don't want to buy a book for a one time use. Thanx.
Old 05-21-03, 01:34 AM
cheese's Avatar
Do you have the model# of the engine?
Old 05-21-03, 05:15 PM
TrackerSD
I'm sorry, I spaced it
The mower number is 917-376250
The engine number is 143-964504
As far as I can tell it is a TVS-115 from crossing the part numbers back and forth. The TVS number was close enough to get me the piston, valves and oil pump from a local dealer.
I have gotten used to fudging numbers over the years from working on my bike
Since the pistons are close to the same size, I was concidering going with the same ring gap. But I would like to get the right settings in case it doesn't like brit.
Thanx again for any help.
Old 05-21-03, 10:44 PM
cheese's Avatar
My book here doesn't show that sears# for reference, so I'll check my other tecumseh books to see what I can find out. You are probably right with your guess, but it would be best to find out for sure. I'll try to get that info for you tomorrow.
Old 06-03-03, 04:51 PM
TrackerSD
Had to cut the grass (the dogs in the back yard were disappearing)
so I took the gap from an A65L BSA twin. It had the same piston size. Thanks for your help tho.
Old 06-04-03, 09:32 AM
cheese's Avatar
Oops...I spaced this time, lol. I forgot to get that info for you. Sorry. Glad you got it going!
