Questionable spark
J A Boggan's Avatar
05-31-03, 11:12 AM   #1
J A Boggan
Questionable spark
When I put a B&S spark tester on my weed eaters and blowers I get a nice fat spark (with a 1/8" - 3/16" gap) from plug wire to ground, on every pull. However, when I connect the new spark plug from plug wire to ground, I get only a measly small spark. Apparently, it is good enough for it runs the engine fine. Dose anyone know why this happens.
mower17's Avatar
05-31-03, 12:10 PM   #2
You might need to clean and regap the plug.
cheese's Avatar
GA
05-31-03, 11:45 PM   #3
Spark plugs have internal resistors. They can change the appearance of the spark. Also the gap on a spark plug is usually smaller than the gap on testers. This makes a smaller spark too.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
J A Boggan's Avatar
06-01-03, 06:43 AM   #4
J A Boggan
Thanks Cheese...Is a DJ7Y Champion the same as a RDJ7Y, without the resistor?
Joe_F's Avatar
06-01-03, 12:08 PM   #5
Joe_F
Yes, the first R in a Champion plug number denotes resistor.
mower17's Avatar
06-01-03, 02:09 PM   #6
Not to but in, but, what is the purpose of the resistor in the plug. Is there an advantage with using a plug with a resistor?
J A Boggan's Avatar
06-01-03, 06:29 PM   #7
J A Boggan
It is supposed to reduce electrical interferrence.
