flywheel is off
Old 06-05-03, 02:17 PM
W
Received 41 Upvotes on 37 Posts
flywheel is off
Well I stumped the pros with a 1967 Briggs engine that I couldnt get the flywheel removed from when the engine blew. After breaking the bolts on 3 different types of Briggs and harmonic balancer pullers, I took it to a friend who does work on large diesel trucks and had him hook up his custom gear puller to it. This puller had wings that gripped the outside of the flywheel and pulled from two points on the flywheel, rather than from the threaded holes in the center of the flywheel. It was heated extremely hot and torque from the puller screw bent the puller somewhat. Even at that, it took a huge blow with a sledge hammer to free the flywheel. It came off intact however, but I know have most of the magnets that line the inside of the flywheel loose now. What is the recommended way to reseal these magnets to the flywheel?
Old 06-05-03, 07:17 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: WML13
Once the magnets come out of the flywheel or become loose in the flywheel, the only solution is to replace the entire flywheel.
There is no other means I know of to secure the magnets to the flywheel. Centrifugal force will fling the magnets out.
It's almost impossible to even imgine how the flywheel could have been that difficult to remove. Personally never had a flywheel frozen onto the shaft like the one you described.
Nor one that had to be beaten with a sledge hammer to remove. I'm now wondering what shaft thread damage resulted and what internal engine damage resulted from that type of brute force???
Regards & Good Luck.
Web Site Host & Small Engine Forum Moderator. "Accurate Power Equipment." Small Engine Diagnostics Services & Repair.
Old 06-05-03, 08:16 PM
mower17's Avatar
Glad to hear you were able to remove it. I once started to attemp to remove a flywheel with a large puller like you described that was made for diesel engines. My teacher quickly stopped me and said that he has seen things brake by pulling from the outside. He said that the flywheel is built strong on the outside, however, near the center, it is a lot thinner, hints the reason for the flywheel puller. Sounds like you had one tuff time with the flywheel. I have never heard of one that was stuck that bad.
Old 06-05-03, 09:45 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
I agree..replace it. It is now an unsafe flywheel, because of the heat, impact of blow, and loose magnets. The cast iron flywheel could now be warped, stressed, and/or cracked. You don't want a stressed flywheel fracturing and flying apart at 3500 rpm.
I also have never seen one stuck that badly. I wouldn't doubt that the crankshaft is either twisted or bent too.
Old 06-06-03, 04:20 AM
W
Flywheel
Well I now have extreme internal AND external damage, so I think my best course of action is to relagate this engine to the recycler and buy a new one. Thanks for your comments!
Old 06-06-03, 01:51 PM
cheese's Avatar
lol...sorry to hear it. Glad we could help, but I wish the outcome were better.
