fuel restriction
Old 06-11-03, 08:47 PM
ringoryan8
engine starved of fuel
I have a honda mower, today i was mowing the lawn and it was running fine, a few minutes later it was stalling and it would only not stall when it was on choke. what could be the problem? Thanks
Old 06-11-03, 08:53 PM
ringoryan8
changing blade on honda
i have a honda mower and need to change the blade. Which way does the bolt turn to take it off. I tried both ways and couldn't take it off but wanted to ask before i tried to hard in the wrong way, Thanks
Old 06-11-03, 11:14 PM
cheese's Avatar
hello ringoryan8!
All Hondas that I have worked on have regular right handed threads, and the blade bolt/nut will be removed by turning it counter-clockwise.
Old 06-11-03, 11:18 PM
cheese's Avatar
Sounds like you have water and/or debris in the carb bowl, and possibly in the tank. Remove the 10mm bolt that holds the carb bowl on and look in it. If there is trash and/or water in it, clean it out and check the bottom of the tank for water too.
Old 06-12-03, 08:07 AM
ringoryan8
i had just completely cleaned the carb before running it because it hadn't run in a long time but i will try it again. thanks
Old 06-13-03, 06:30 PM
ringoryan8
thanks, that worked and there was water in the tank!
