2 Cycle Question
Old 06-16-03, 02:13 PM
jaknik2
Lawn Boy Question
I have a Model 8157 Lawn Boy Supreme that seems to run good for a while then bogs down and then after a while hits full stride. The cycle repeats.
I have a new spark plug and my neighbor cleaned to carb. Most of the folks I've talked with suspect the C.I. ignition module is overheating.
What do you folks think?
Jak
Old 06-16-03, 11:38 PM
cheese's Avatar
Hello Jak!
I don't believe it is an ignition problem....I think that it is running too lean. Unscrewing the air-fuel mixture screw about 1/8 of a turn will probably cure it. Another possibility would be that the governor vane is sticking.
Old 06-17-03, 04:34 PM
jaknik2
Lawn Boy
Thanks Cheese! I'll give it a try. This mower is in very good shape for its age and when it is working right, it cuts like a champ. I do notice that it seems to load up while emptying the bag (it has a brake clutch).
If it was running right, my only complaint would be that it is rather loud.
Jak
