No Ignition Spark
Old 06-19-03, 03:03 PM
wallyk
JD 116 with B&S 16HP eng won't start
there is no spark to the plugs, I removed the plugs (2) and then put the wire back on and then cranked the engine and there is no spark. I tried the plugs on my lawnmower so they do work. Is the points or is it the coil? Does anyone know how to test these items? I'm not sure if I have electronic points, how do I tell? How do I test the coil? The engine cranks over very fast and I checked the gas to the carbuerator and I can see it coming in to the carb when I crank the engine. I also took off the gas-line hose and cleaned out the gas filter. This is a briggs & stratton engine and I have never replaced any points or anything as I bought the JD 16 lawn tractor used. So, I need to know how to find the points and how to test them and also how to check the coil. Thanks in advance for your help...
Old 06-19-03, 07:37 PM
cheese's Avatar
Hello wallyk!
That engine doesn't have points. To check the coil, look on the side of the engine for a single black wire that has a small white connector on it, connecting it to another wire. Unplug it. Then check for spark. If you have spark, then the wire that runs from the mower to the engine that you disconnected has a short to ground somewhere, possibly a bad safety switch. If it does not spark, remove the flywheel shroud and unplug the same wire from the coil. Check for spark then. If still no spark, your coil is bad.
Let us know how it goes!
Old 07-24-03, 02:23 AM
wallyk
the coil was bad!
It was the coil alright...thanks for the help.
Old 07-24-03, 08:25 PM
cheese's Avatar
Anytime, Glad we could help!
