Ignition Problem
lockjawkennels's Avatar
06-29-03, 05:20 PM   #1
lockjawkennels
craftsman lawnmower ignition
my dog took my key out and not it is nowhere to be found....
is there anyway to hotwire it or start without a key?
thanks for you help
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
06-29-03, 05:37 PM   #2
Hello and Welcome lockjawkennels to the Do-It-Yourself Web Site and the Small Engine forum.
Should not be any problem if the current key switch is a simple two position two wire device.
Simply remove the existing key switch. Detach the two wires. Install a toggle switch and reattach the two wires. Polarity is not a concern. The switch is a grounding only device to kill the engine.
The key part of the switch is a safety device to prevent children from starting the engine without the key. I assume you have no children or they are grown and you can leave the key installed.
If there is no safety concerns for accidential engine starting, the toggle switch will work fine. The are available at any automotive parts stores in your area. And they are not expensive either...
If you need further assistance, use the REPLY button. Using the reply button moves the topic back up to the top of the daily topic list automatically & keeps all communications in this one thread.
Regards & Good Luck.
Web Site Host & Small Engine Forum Moderator. "Accurate Power Equipment." Small Engine Diagnostics Services & Repair.
Fast...Fair...Friendly & Highly Proficient Services....
06-29-03, 05:42 PM   #3
lockjawkennels
wire details
there is one red, one black, and then two sets of two yellow wires that run out the back of the ignition...
there is a seat and clutch pedal safety on the lawnmower....
i just dont know which ones to put together to start the mower...it is a craftsman 13 hp OHV manufactured in 1996
thanks for your help
mower17's Avatar
06-29-03, 06:48 PM   #4
You could go to a small engine shop and buy a new key. For example, most briggs ignitions use the same key, so if you lose one, you can just grab another one off of another mower with a briggs engine.
CAL
06-29-03, 08:49 PM   #5
"I see said the blind man."
A riding mower with a key switch.
Hello: lockjaw
Interlock safety switches & devices too.
As mower17 said, get a replacement at the dealers. It should be as common as a landard key used with a wave runner or jet ski.
Anyone with one can ride anybody elses machine any time.
Useless for security.
Safe for accidental engine starting of mowers.
Great for engine killing of jet skis & wave runners when riders get tossed off.....
Regards,
Sharp Advice
