Contaminated Fuel
Old 07-14-03, 10:39 AM
BamaChris
Contaminated Fuel
My mother in law accidently filled the lawn mower fuel tank with 2 cycle engine oil mixed with gas. Now it will run for about 5 seconds and then quit. How do I flush out all the old contaminated gas from the system? Thanks
Old 07-14-03, 11:29 AM
Joe_F
Take the fuel tank out, dump out everything from it. Replace the fuel line. Try cleaning the carburetor with a spray cleaner.
If that doesn't help, carburetor rebuild time.
Old 07-14-03, 09:42 PM
cheese's Avatar
Hello BamaChris!
What kind of engine (brand and HP) is on it? If it is a briggs classic, you can remove the tank and carb all in one assembly, dump it, rinse it with fresh gas, and reinstall. If it has a fuel line, you could remove the line from the carb and let the tank drain into an acceptable container, swish a little fresh gas around in the tank, and recconect the line.
