Crankcase Hose
kris74's Avatar
07-16-03, 08:47 PM   #1
kris74
Crankcase Hose
john deere lawn tractor 116 117/oh. how will the crankcase hose affet engine operation if it's broken? will this cause backfiring?
cheese's Avatar
GA
07-16-03, 09:05 PM   #2
Hello kris74!
Are you referring to the crankcase breather tube? If so, it should not cause backfiring, but it will allow the engine to suck raw-unfiltered air into the carb and cause engine wear. Replace it soon. Backfiring can be caused by too lean of a fuel mixture, sometimes too rich of a fuel mixture, valvetrain problems, mis-adjusted points. When does it backfire?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
kris74's Avatar
07-17-03, 03:15 PM   #3
kris74
it's backfiring when i shut it off. ? ? ? ?
cheese's Avatar
GA
07-17-03, 10:26 PM   #4
What brand and hp engine do you have on it?
God bless!
kris74's Avatar
07-18-03, 12:21 AM   #5
kris74
john deere 116 117/oh does'nt say, my dad says it has a kawaski.??? seems it wonr idle down all the way, linkages are clean, think it nees a minor idle adjusment????checking the spark plug gaps in the morning, it has two plugs and a throttle body looking carb.
cheese's Avatar
GA
07-19-03, 12:46 AM   #6
Sounds to me like the carb needs cleaning. Also, on the bottom of the carb bowl, there may be a fuel shutoff solenoid. If this is not closing properly, it will cause backfiring. Kawasaki makes a great engine, and the carbs are easy to work on. Just be easy with the float needle. They are expensive to replace in comparison to most needles.
God bless!
